I have some home videos that I've recently converted from Vhs to DVD.
I wish to do some voice overs throughout them, so was wondering how I would go about doing this, or what software to use.
My plan is to rip the DVD's to the PC as high quality Avi files, them I have software that allows me to record sound from the microphone. All I need to know know, is how I go about getting the Mp3, Wav audio clips inserted into the various parts of the Avi video. Then once all done, I'll simply encode it to DVD again & burn.
Thanks for any help received!
If you just want pieces of voice-over inserted it is probably best to re-edit the movie. Just about any NLE program (Windows Movie Maker, EditStudio, Vegas, etc) that supports multiple audio tracks will let you do it.
In theory, you could de-mux the audio and use a good audio editor to merge in your comments and then re-mux (or not, depending on your DVD creation software). But you won't be able to see the video while you work and getting the file right can be a bit tricky..
I just did something sort-of like this using N-Track.
Do you want to make your comments a permanent part of the movie or are you trying to make an optional "director's commentary" type of thing?
Audio software that "overrides" default file-types/icons
By djdust in forum Software PlayingReplies: 0Last Post: 15th Apr 2011, 03:09 -
AVS Media "demo" file-conv S/W inserts voice into cvtd music files
By charlessmall18 in forum AudioReplies: 0Last Post: 2nd May 2010, 16:17 -
DVD software's audio is "scrambled"
By takearushfan in forum Newbie / General discussionsReplies: 8Last Post: 11th Sep 2009, 05:38 -
how to create "thinking" effect(when someones voice plays in head
By bojadada in forum AudioReplies: 3Last Post: 20th Dec 2008, 12:23 -
Software to Record Voice/Audio. Diary!
By UmmAddan in forum AudioReplies: 4Last Post: 28th Jun 2008, 20:43
