why is it what when i capture from vhs i drop loads of freames yet with exactly the same sttings if i capture from my camcorder i hardly drop any frames at all?
cheers
Ish
I see this too from VHS. Out of 707 frames I've dropped 88. That seems high to me, but I can't seem to improve upon it.
-Moondance -
There are two reasons why dropped frames occur.
1)Your computer is too slow to get them all.
2)Your videotape is flawed. Physically unable to make the frames work. It doesn't even matter if it's re-recorded, it's in the tape itself. If you find one like this, mark it, and NEVER use it for capturing.
BTW, #2 is the ONLY reason my 'puter ever drops frames.
I see it a lot, actually. -
Ah. It must be #2 for me. The tape has been used at least 4 times before the stuff I'm trying to get.
Here's one for the silly file...
Actually look at the quality of the tape your capturing _before_ you capture it! <duh> Because it looks SO much better in that tiny preview window. <smile>
I spent quite some time over a tape that wouldn't capture well only to discover that, well, it does look like *)^%.
Give me a day.. then I will be able to laugh about it..
-Moondance
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 22:40 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
