Hi.
How can i test my drive to see if it's working ok.
I've had trouble burning media, i have a pioneer 110d, and i have Firmware v1.39
In regards to the media, i have used this media in the past and it has worked ok with my drive
but this latest tub, i've used 12 discs and all 12 discs have failed to burn, i think i have a faulty media but the supplier keeps telling me it's my drive and firmware.
And if i want to send them back i have to pay the P+P
Datawrite Titanium Full Face Printable White 8x -R
http://www.discandink.co.uk/acatalog/DVD_R_Std___Printable.php
Looking here http://svp.co.uk/products-solo.php?pid=820 they might be CMC or they might be TTG02. I've not had a lot of sucess with either. At least buying from SVP, you know exactly what you are getting.
Although I wouldn't expect you to get 100% failure rate. Have you tried your burner with anything else? -
burn a known good quality blank like a taiyo yuden amd see if it works. it's probably bad media like you think.
Since you haven't tried any other media to determine if the media is the issue I would buy myself a different brand and try it to see if there is a difference.
Burning to Hard Drive
By spacebiscuit in forum DVD RippingReplies: 8Last Post: 15th Dec 2011, 10:00 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
Drive Not Burning
By robburne in forum DVD & Blu-ray WritersReplies: 3Last Post: 19th Nov 2009, 20:57 -
App to test hard drive reliability....
By kenmo in forum ComputerReplies: 1Last Post: 15th Jan 2009, 08:54 -
ConvertX2DVD "test drive" results question
By Seeker47 in forum Video ConversionReplies: 3Last Post: 8th Nov 2007, 00:24
