Any ideas why I can play some burned DVD+R (Memorex 4x) discs one day on my Samsung DVD S222 player and then not on other days?
The discs play well on other DVD players at work or on my PC.
I would have thought that it would either play all of the time or none of the time.
Is there something that I could do to fix this, can you do a firmware upgrade on standalone players?
I had a similar intermittant play problem with a Philips 75.
I never cured it, but, I did discovered that it's ability to play
problem disks decreased with warm up time.
After about a 45 min warm-up time it would again play ALL problem disks.
You might try giving it a bit of a warm-up first.
(I figured my problem was either the dye on that brand or the laser
slowly wearing out)
hope this helps
mikelLosing one's sense of humor....
is nothing to laugh at. -
Never tried that but worth a shot. Although my 5 year olds may not be as patientOriginally Posted by mikel
AVI file won't play via stand alone DVD player
By 3lutz3toe in forum MacReplies: 2Last Post: 24th Dec 2009, 06:37 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
Key 2 getting DVD-/+R/RW’s 2 play on stand alone DVD players/recorders/not
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 12:07 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 17:48 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 17:53
