I had convert a movie from rmvb format to avi format.The movie contain 2 parts.(example: CD1 and CD2 for 1 complete movie) Then i convert the avi file to DVD.When it complete convert,CD1 got 1 folder which contain audio TS file and Video TS file and the same goes for CD2 when i finished converting.
The question is how do i burn this 2 files into the DVD-R using Nero 6.I had try adding this 2 files into the DVD-R but it prompt me that it can't because i think it's contain the same name folder and file.i had try rename it and it still can't.
Can someone out there please advise me how to make it work.![]()
Open CD1.avi in VirtualDub. Set both video and audio to Direct Stream copy. Then File - Append segment, and add CD2.avi. File - save as. Give a name to your new only1CD.avi.
Process to DVD.
HTH
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD burning problem
By eunhye in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2008, 20:04 -
DVD Burning problem
By eXit- in forum Authoring (DVD)Replies: 7Last Post: 1st Aug 2007, 10:42 -
DVD burning problem
By Neil_2004 in forum DVD RippingReplies: 12Last Post: 30th Jun 2007, 18:14 -
DVD burning problem
By ea7770 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 15:17
