I finally got the time to convert some of the series I taped on VHS to SVCD. Don't get me wrong, I don't wanna do it in realtime.
I got the ATI AIW128, MMC 7.1 with 4.13.7192 drivers. For capturing I use ATI TV 7.1. I intend to capture MPEG2 (as "MJPEG" - I frames only), but I have a slight problem. The captured mpeg2 files are too fast, although @ 25fps, and full of audio clicks! Seems to be a problem with sampling rate. The funny thing is that captured AVI files are 100% OK, no speed problems, not audio glitches, I tested 10 minutes without sync problems. Now I wouldn't have a problem if TV 7.1 would let me choose a x*576 resolution for AVIs, but as most of you know, it doesn't. Another problem with ATI TV is that it doesn't let me change the codec properties, not too much of a problem as I use HuffyYUV, but annoying nevrtheless.
So, did this problem occur to you? Please lemme know!
PS: Almost forgot my system:
OS - Win98 (only for capturing = clean install)
CPU - Athlon XP 1500+
Ram - 256 DDR
Sound - Terratec EWS88 MT
HD - IBM DCAS (7200)
<font size=-1>[ This Message was edited by: resonator on 2002-01-04 18:14:54 ]</font>
Upgrade to MMC7.5 and then see what happens. But make sure you have the latest drivers from ati website.
You're lucky, MPEG2 capture doesn't work at all with my AIW 128 16mb even with the MPEG2 codecs installed. BTW, I've tried all the 7.x MMC. Seems like I might have to go back to Win9x - then I can use Vdub to capture.
Fast denoiser?
By Mephesto in forum EditingReplies: 4Last Post: 10th Jan 2012, 20:32 -
How fast is enough?
By ahhaa in forum ComputerReplies: 6Last Post: 7th Feb 2009, 01:58 -
Video is going too fast
By wiksten in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 14:27 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
