Results 1 to 12 of 12
  1. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I've been using various CD burning software under Win98 for my Sony CRX140e without any problems for years now. I recently installed Win2k SP4 on the same machine. Now nothing will burn successfully, sometimes I apparently get halfway through a burn and it fails; sometimes it just aborts immediately.
    I've tried Nero 5.5. Fireburn, CloneCD.... none work
    I used ForceASPI to install Adaptec's 4.60 ASPI. Still failed.
    If I reboot to Win98, it all works the same as ever.
    Any advice?
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    very strange bug. Never heard of... Does your Sony CRX140e has the latest firmware?
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I'm pretty sure this is a Windows problem. But I did check Sony's site; there aren't any updates. I have firmware 1.0n as I got it. I found an update that is supposed to be 1.0s (with Japanese text) on Driverguide.com, but I'm suspicious of running things from that site, anyone can upload anything there and I see a lot of files that I know are bogus if not necessarily harmful.
    If anyone is interested I'm attaching the output from Nero's Infotool if the forum will let me.
    infotool.txt
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Well, I'm still stuck.
    I now have to reboot to Win98 to burn anything. That at least indicates it's a software problem.
    How do I make Windows recognise my burner?
    The device manager for Win98 says it's using the standard MS drivers. Seems identical to the Win2k setup.
    Any clues gratefully accepted.
    Feb 2004
    Australia
    Go to start , setting's , control panel , add/remove program's .
    If sp3 for win2k is not listed , bingo .
    Uninstall sp4 , visit link provided below to visit ms for sp3 pack , download and install and see what happen's .
    If it work's , then install sp4 for win2k ... retry .
    Last , firmware update for burner .
    There is also a 30mb wrapup of the latest update's ... if ms dosent hand it over , do a web seach for the kb?????? , I found the english patch on and egyption site .
    Strange behaviour from ms , it gave me the massive sp4 pack , but refused the final 30mb round up ... idiot's .
    As for that Sony CRX140e unit , they do have that common fault as reported by other owner's on other forum's ... if it's older than 2 year's or done alot of work , it might be worth while to replace the the unit .
    Liteon , lg , and sony latest unit's have no issue under win2k with sp4 ... I own more than 9 unit's .
    Ps : check out
    http://sony.storagesupport.com/cdrw/win2k.htm (seem's you should have had sp3 for win2k first) .
    Also
    http://sony.storagesupport.com/cdrw/index.htm (choose your model)
    Finally
    http://www.cdrinfo.com/Sections/Firmware/SingleModel.aspx?DriveId=278 (firmware here)
    Should get you up and running .
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If sp3 for win2k is not listed , bingo.
    Uninstall sp4 , visit link provided below to visit ms for sp3 pack , download and install and see what happen's.
    If it work's , then install sp4 for win2k ... retry.
    Could you explain that? SP4 is supposed to include all previous SPs.
    In fact, I installed Win2k using a slipstreamed CD, including SP4. I saw Sony's site only mentioned SP3, but I thought that was just because they weren't up to date. But I'm ready to try anything if there's a reason.
    Last , firmware update for burner.
    Is that just on general principle or are there known issues with firmware and Win2k? I have 1.0n; I discovered 1.0s on an NEC.jp site, so it's probably legit, though all the doc is in Japanese so it's a leap of faith to install it. But I'll go ahead.
    They don't want to make it easy for people to stay with Win2k; they don't sell it any more.
    -- But a very good place to sort this out is at http://www.msfn.org/, there are several groups there providing various ways to customise Windows, even an "unoffical SP5" that rolls up all the updates. See also http://www.autopatcher.com/.
    Could you be more specific about this "common fault"; I'm floundering around here because pretty much all I can say is "it doesn't work" and can't find a way to describe it to let me diagnose the problem.
    Thanks a lot for taking an interest. I'll try the firmware first, possibly the SP rollback.
    I also checked out new drives, a DVD burner is about half what I paid for the CDRW, and about 10x faster... but even if I upgrade, I still want to solve this.
  7. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    It might be your ASPI drivers. I'd recommend giving ForceASPI a try. You can use that tool to check your ASPI drivers and update them. ForceASPI is listed in the tools section, https://www.videohelp.com/tools?tool=ForceASPI_Drivers
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I did that, as noted in my first post. Everything is at 4.6.
    Jan 2003
    Best Coast, Canada
    I used to have the same drive and it worked perfectly on my old dual-boot PC with 98SE and W2K in either OS. I dunno what causes your trobles but I'd recommend reinstalling W2K clean if it's possible. My point is, it may take less time to reinstall rather than keep troubleshooting the problem.
  10. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Ahh, so you did. I was wondering why no one had suggested this yet. I need to read more carefully next time. There's really no reason why your burns fail under W2K and worked in W98.
    As Dubber suggested, your best bet might be a format and reinstall on W2K. Then I'd install my burning software and see if that works before installing anyother applications.
  11. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I got the CD burner working.
    After checking out the price of a new CD burner, I saw that DVD burners were hardly much more. So I bought one today. I haven't connected it; but I did install the OEM Nero 6.6 that came with it. And now my old Sony burner works -- not just in Nero, but all the other burning apps.
    I did a Nero Infotool report and compared it with the earlier one. I can't see which changes were critical. There are a dozen or so new drivers, most have cryptic names, but some at least I can tell are various sound or video codecs, so I don't know if any are hardware related.
    So I'll just have to put it down to Nero voodoo.
  12. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Glad you got it working. Good job of troubleshooting.
