    Dec 2003
    Spain
    Hi,
    I have Muxman 0.15, which shows 4 audio streams. My project has 6. How can I load the six?
    Thanks in advance
  2. Hi-
    You'll have to subscribe to the Premium version to be able to include up to the full 8 audio streams:
    http://www.mpucoder.com/Muxman/
    I might suggest authoring with IFOEdit instead. I believe it can take your 6 audio streams.
  3. AFAIRC you can also use the free muxman version, but you will have to edit/create the mxp file yourself to use features which are not covered by the gui.
