Hello, sorry to disturb you all. I am newbie here. Recently, I call lame.exe from my software to do the encode and decode part by the help of a friend. My software is designed to record and play wave file in audio and visual. It is used in our speech rehabilitation centre to help children with speech problem. I work part time there.
I convert the wave file recorded by my software to MP3 by calling the lame.exe. It happened successfully.
Then, since the software can only play wave (cannot play MP3), I use the lame.exe to convert MP3 to wave file again. But, my software failed to play the wave giving the error of “Unsupported File Format”.
I checked both the wave file before and after conversion. They give the same format: PCM, mono, 16 kHz, 16 bits, 256 kbps. I could not figure out why the software cant play the wave file after conversion. The software can play the wave file recorded by the software itself.
Then, I tried by changing “- -decode” to “- - decode –t” but I get another error of saying that “Invalid File Type”. The, I tried again for “-x” because I thought there may be problem of little endian and big endian. The problem is still the same.
Hope you can give me some ideas or suggestions. I promise to do it as independent as possible, please, please. Please guide me at this very beginning.
Results 1 to 1 of 1
MP3 (LAME) in Avidemux
By moiz in forum AudioReplies: 2Last Post: 18th Feb 2012, 10:18 -
Lame not showing up in VirtualDub
By DonGallego28 in forum AudioReplies: 3Last Post: 29th Oct 2008, 14:40 -
What would you do if you just saw a lame video?
By KnifeSoldier in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2008, 05:23 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 08:16 -
To lame for HD?
By rhythminmind in forum Media Center PC / MediaCentersReplies: 5Last Post: 10th Oct 2007, 19:38
