  1. Hello evry1
    got a little question
    i'm new in de svcd scene and wanna to know
    if i use cce-sp 2.5 demo version with dvd2svcd
    will it work fully ??or do i need something ???
    because i'll will not pay 3000 buck for a program
    so can i use the demo yes or no ??
    if not plz send me a e-mail for a helping me about it
    sorry for my bad english
    thnx
    _________________
    Youre Guide to HeLL
    <font size=-1>[ This Message was edited by: HeLLDoG76 on 2002-01-02 07:01:29 ]</font>
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Seems that you are new to this site too.........
    Did you never read the request from the administrator?
    NO QUESTIONS ABOUT CRACKS!!!!!!
    Please show a bit respect for the creator(s) of this site
    Jan 2002
    He's not looking for a crack. Or at least he's not asking for one (IMHO).
    What he wants to know is will CCE 2.5SP *work* with DVD2SVCD.
    The answer is *yes*.
    However, if you use the demo version it will add a CinemaCraft logo to the video sequence.
    If you want to eliminate the logo, get out your wallet.
    Mark
  4. I guess you are drawing the question. What is meant by "work"? Can DVD2SVCD frameserve to CCE like it can to TMPGEnc?
  5. the light version is $250
    anyways most multimedia processing software is expensive because they beleive the professionals that use it will make more than enough to cover the 4 grand (the 2 processor version is so expensive they dont even put the price on the site
    i have to say maybe cce is faster and the quality is a bit better than tmpgenc.. but tmpgenc is great even if it were say $100.. but its awesome for free. it makes svcds fine (that burn and play fine on my dvd player)as well as xvcd and xsvcd
    cce produces professional quality and for $3980 i would expect no less
  6. Another problem with TMPGEnc is that it's MPEG-2 capabilities have timer on them.
  7. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    1 - there was a question for a crack, and I reacted to that. The message was edited afterwards, and the word crack was removed.
    2 - Helldog, As stated before, you can use the demo version, but it has two limitations; A - there will be a logo in your picture, and B - you can only encode for five minutes.
    CCE 2.5 (and only 2.5) will work correctly with DVD2SVCD. I have started using DVD2SVCD this week, and I have to say that I am thrilled about the quality of CCE. I encoded dozens of (S)VCD's with TMPGEnc, and CCE has a far better quality in my opinion.
    I will mail you for more background information.
    Regards
    The Dutchman
