So I am trying to burn a movie (avi file), but Toast has to encode it first. It is like 95% complete, then this error appears: "Result code = -50"
The encoding does not finish and I am unable to burn.
Also...when I play it on VLC I hear audio, but none with quicktime.
Any ideas what is wrong?
Thank You.
Are you trying to burn a playable DVD, or just making a data disc?
As for the audio, VLC handles those files better than QT does. But I use a GREAT program called MPEG Streamclip which will convert video files to either dv, mpeg or avi. It will also convert the audio so you can hear it using QT.
T -
http://forums.support.roxio.com/index.php?showtopic=616&hl=Result+code+\=+-50
Result code = -50001, Fails at end of write, before Verification"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
result code errors are passed directly from the mac os to toast... toast then reports them.
so... it's a mac os error... searching on apple's site brings up about 500 different causes of the -50 error... but it's most likely related to an issue between the source file and the burned copy.
are you using the mac while burning?
don't move the file around... don't rename it... don't try and play it...
better yet... don't do anything until burning is done.
have you tried playing the entire file through to the end in a player app before burning?
does it work?
have you tried saving as a disc image instead of burning it?
have you tried turning verification off? -
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 15:28 -
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 17:46 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 12:58 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 23:11 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 03:23
