Well, the title is pretty much self-explanatory, but for the people who didnt catch it...
I just want to remove that "My Bluetooth Places" shortcut that got installed on my desktop when I installed my USB Bluetooth Dongle. When I right-click, there is no option to remove or anything.
Any help is appreciated, and thanks in advance
Results 1 to 13 of 13
"The statement below is True,
The statement above is False" -
I installed my bluetooth dongle and I never got the "my bluetooth places" icon... I've been trying to find it since then.
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
The dongle wont work anymore if I do that.What if you uninstall your dongle drivers?
The brand of my dongle is Kensington, if that helps any.I installed my bluetooth dongle and I never got the "my bluetooth places" icon... I've been trying to find it since then.
True, but is there any other way of removing it. I really dont want to install another program to get rid of an icon. If it comes down to it though, I might go this way.Microsoft powertoys Tweakui lets you remove it.
Thanks for the replies"The statement below is True,
on the desktop or in your taskbar
Found this on another site. Dont know if it works cos I havent needed to try it.
"HOW TO REMOVE THE ANNOYING "MY BLUETOOTH PLACES" ICON FROM THE DESKTOP THAT DOESN'T WANT TO GO AWAY!
Open up the registry editor (Start> Run> regedit)
Browse to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Desktop\NameSpace\{6af09ec9-b429-11d4-a1fb-0090960218cb}
Delete it. If you are paranoid, choose to export it first (right-click> export), so you can add it back later if you need to.
Restart your computer for the changes to take effect." -
Well to test, I just clicked on my icon on the desktop and pressed delete, and it deleted.
I wasn't able to do that.on the desktop or in your taskbar
That didn't work for me either.Well to test, I just clicked on my icon on the desktop and pressed delete, and it deleted.
All gone! It's not there anymore. My only concern is, when I deleted that in my registry, is it going to mess with anything else? Thanks for the replies guys!Found this on another site. Dont know if it works cos I havent needed to try it.
Restart your computer for the changes to take effect.""The statement below is True,
Probably wont mess anything up. But if it does you can import it back into the registry by double clicking the file you saved (if you did save it first).
Alright, great! I did make sure to make a back-up of my registry file. Thanks for all your help guys!Probably wont mess anything up. But if it does you can import it back into the registry by double clicking the file you saved (if you did save it first)."The statement below is True,
HELP!
I am runnig Windows 7 and i cannot find the...
{32B4C379-4AC0-45F2-939C-D4E7ADA56DC5}
or the...
Freaking hate that bluetooth icon... it ruins the clean look of my desktop.
Anybody got a better solution?
I would much appreciate some help with this simple, but annoying problem.
thanks.
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 11:09 -
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 13:35 -
How to re-add "Show Desktop"?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 20th Sep 2007, 23:09 -
is it safe to remove "analyze" files from DVD Shrink?
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2007, 15:18 -
REMOVE Phillips DVP-642 "angle" indicator
By gumbico in forum DVD & Blu-ray PlayersReplies: 35Last Post: 28th Jun 2007, 13:55
