Hi all
A friend wanted to watch some video files I'm downloading from the net and since I'll be getting some more files that he'd be interested in the future I decided to burn them on to a rw dvd disc.
The discs I got were imation dvd+rw. The authoring and burn process went fine. I decided to give them a test run on the el cheapo panasonic dvd player I've got.
The disc sort of worked. The first time I put it in it worked fine. The second the player said bad disc, so I turned the player on and off and it worked just fine. I watched the disc but eventually it just froze.
My questions are:
1. Is there an inherent problem with playing Dvd+rw or -rw in dvd players?
2. Is the problem with my dvd+rws? If so what brands would people recommend?
"I'll make you fun size!" Reduco
I would say it's more of the DVD player problem. Newer DVD player should play fine. Especially those DVD players with DVD+RW or -RW on their playback list.
If your burner allows book type setting (bitsetting) +RW discs then set it as DVD-rom. I have one Apex dvd player that won't accept my DVD+RW unless I do that. My Philips player sometimes fails to load a disc when I forget to set the book type but never fails when I do it.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35 -
dvd player vs dvd recorder for playing back dvds
By JCWagener in forum Newbie / General discussionsReplies: 5Last Post: 14th Mar 2008, 17:50 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
Intresting Dilemma with burning and playing DVD-Rs in my DVD Player
By John Shumate in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 03:53
