whats the best way to edit music video audio because i cant get it to sond good like the ones i use to download off the net the![]()
Are you capturing these music video's yourself?
If so...
What hardware are you using for capture?
What software are you capturing with?
What format for audio are you capturing to?
What is the bitrate for the audio you are capturing?
If your working with audio alone and your captures sound good and you just want to edit them for free try Audacity. For MP3's you also will need the Lame encoder. -
hauppauge-150
wintv2000
wintv wave
224
and im stuck in mono cant use stereo at all -
If the audio bitrate is 224 then your not capturing to PCM audio (lossless). Try changing the settings in Wintv2000 to PCM wave. This will give you the best quality you can capture to.
Also if you just want the audio and not the video try using Audacity and just capture the audio through your sound card and not through the tv tuner card. Take the line out of your cable box (if you have one) or out the back of a VCR (if you have one). You'll have Stereo sound and it should sound great and not like AM radio. -
rmr - I don't believe it is possible to record audio in WAV (a.k.a. PCM) format with your card. That's why you don't see the option. Unclebud is not familiar with your card, which is why he suggested this. Your card will only capture MPEG audio.
Try using a very high bit rate, such as 320 or 352. We don't know what your source is, but I will warn you that if I try to record something from a VCR, it sounds like crap. I always have hum that I can't remove. I've tried every normal method to eliminate the hum (different power sources, etc.) and nothing works. Fortunately, I rarely need to record from old videotapes. -
sorry to go off a little here but jman did you try using a 60hz notch filter? this should resolve ground loop hum.
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 03:59 -
Trying to separate music from the rest of the audio in a video.
By walkerrhodes in forum AudioReplies: 8Last Post: 21st May 2011, 04:18 -
help syncing audio .wav of music to video of musician
By tspnyc in forum AudioReplies: 6Last Post: 1st Dec 2010, 18:27 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 13:02 -
how to replace an audio track to a music video and getting it to synch
By alarmsman in forum AudioReplies: 1Last Post: 20th Jun 2007, 15:06
