I own a psp...I currently only have a 32mb memory stick. Im looking for some thing that will
Compress a MPG-4 file...for example 3420kb to 200kb? or samller. Iv found and used several program. one called "X-oom" it was a 5-limit conversion. and U had to buy it after 15 days. Im looking for some thing free and simple. ive been looking for over a week now on the internet. Cant seem to find anything that will compress a simple MPG-4 file. plz help![]()
try super or psp video 9 (i don't know if it supports the mp4 container though)
but 3 mb to 200kb wont look good... -
Originally Posted by GANZO
There is no 'zipping' of video files only re-encoding, which for the amount of file size reduction your asking for will result in pretty awful video.bits -
He wants to put the result on a PSP.
SUPER and PSP Video 9 should be able to reencode the video to the smaller size and format suitable for a PSP. However, it won't guarantee that you'll be able to fit the result on your Memory Stick (especially if you haven't bought anything higher than the 32MB Stick that comes with the PSP) - the PSP format is fairly strict, if I remember correctly, though I think (I'm probably wrong) one of the recent system updates allows you to play WMV videos straight from the Sticks.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
So what do I do with "NTSC Compatible" .mpg file?
By brassplyer in forum Authoring (DVD)Replies: 6Last Post: 29th Sep 2009, 15:12 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40 -
Trying to get a video_ts file, but getting ".avi.ff.mpg"…
By whoracle in forum ffmpegX general discussionReplies: 6Last Post: 22nd Jul 2007, 22:14 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
