    Perth, Western Australia
    Hi
    I have just "purchased" a copy of Cinema Craft 2.62 and was wondering is there any "how to" use it guides either on this site or elsewhere. I believe you can use it as a frame server in conjnction with other programs such as DVDx? Im realtively new in this area and so what like the instructions to be simple
    Ive been told that the qaulity is exceptional however now I would like to get my hands on some good instructions?
    Regards...
    T 3 X
  2. In my guide in the encoding, there is a relativly newbie on how to use it with FlaskMPEG, but the same can be for DVDx and all other Plugin using programs that use it
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. yes i recommend to use Sefy's guide on doing it with CCCE becuase i helped him with that ,it it a very simple guide on how to make a good VCD out of CCE and simple to use
    OK
    Thanks Sefy
    Im stuck already... how do I connect the two programs together. How do I connect CCE to flask as a plugin?
    Ive downloaded Flask... but when I open Options/Select Output, obviously CCE isnt there.
    Do I have to put CCE in the flask directory?
    T 3 X
    Does anybody else know how to connect CCE to Flask?
    T 3 X
  6. u have to install cce plugin for premiere and put the program to flask folder or u can frameserve using videoserver to cce
    OK
    Im following the guide but I got message like this:
    "ICDecompressGetFormat{}failed :-2"
    Unbelievable
    T 3 X
  8. There's a good guide and a CCE discussion forum at http://www.doom9.org
