Hey all,
Anybody know how to convert .dyc files from the CDC32 (webchat) program ???
Regards,
John Brondum
Of course you could always ask them if they know a way to do it
http://www.dwyco.com/
or, if worse come to worse, you could play it out to an audio recording device or another computer and recapture it.
Worth a shot
baz
Bazz00ie,
The people behind CDC32 is no help, they tell me to just use their software and they don't support anything else
I tried plying thru CDC32 and then use use Windows Media Encoder the Screen Capture recording from that window, but it was all black. Guess that is because of the overlay ?!?
Regards,
John Brondum -
Hmmmmm,....
Well, dealing with unique formats such as "*.dyc" poses a bit of a problem. If they can't provide a converter of any sort that can help you then you have to find another way to get the video. I've had trouble capturing video from the Media Player as well and in those cases I've had to play the video out to a VCR then re-capture it back onto my computer.
If your system doesn't have a TV-out then you may have to borrow a friend/family member's computer that does.
If you have some cash to spare, TV-out cards are becoming less and less expensive.
Good luck
baz
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 08:50 -
Queing multiple Video Files for Conversion
By Bullhead in forum Video ConversionReplies: 1Last Post: 16th Mar 2011, 04:33 -
batch conversion of mp3 files
By z999 in forum AudioReplies: 2Last Post: 14th Mar 2010, 13:33 -
Does a files resolution affect conversion speed?
By perdomot in forum Video ConversionReplies: 4Last Post: 5th Nov 2009, 06:22 -
Conversion of 2.35:1 Source to QT files
By ehmjay in forum MacReplies: 3Last Post: 4th Nov 2008, 02:55
