Is it possible to keep the CC with TMPGEnc DVD Author? Every time I make a disc, it removes the captions. I'd like to keep them if possible.
If you have to encode the video, then they are gone. Get an authoring program that can insert them during the authoring process.
However, if you DON'T encode, then they are still there, but you have to go into IFOEdit to enable LINE21 data. Open IFOEdit, open the VIDEO_TS.IFO file, double-click on your video, and check the "CC for Line 21" "field 1 in GOP" box.
Save, then exit.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Subtitles are on factory DVDs, captions are done on the TV. These are recordings, not retail DVDs, so they are CC, not subtitled. There's no encoding, I just edit the commercials out, make menus and burn.
Closed Captions - Embedded in AVI
By talbot_sk in forum SubtitleReplies: 13Last Post: 27th May 2011, 06:53 -
No Closed Captions on Computer, Only TV
By JimBarbasol in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2009, 18:17 -
Closed Captions and ProjectX
By sambat in forum DVB / IPTVReplies: 12Last Post: 29th Mar 2009, 04:41 -
closed captions and dvr/dvd
By mosk3609 in forum DVD & Blu-ray RecordersReplies: 30Last Post: 23rd Jun 2008, 23:53 -
Elusive closed captions
By CeciliaM in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2008, 05:45
