Hi,
I have a panasonic digi camcorder it has a SD memory card slot, can I record directly onto the card? Im thinking of course yes but how much footage can I record? Lets say I want to capture 1 - 2 hours worth of video footage then what size memory card do I need?
Also please can you advice me what equipment and software I need to do the following please:
a) Transfer the video footage from memory card to pc
b) Record video footage from PC to VHS without loosing any quality
c) Add images to the video footage i.e. lets say credits at the end, or introducing chapters ( 2 - 3 secs long)
All responses would be most appreciated...
Thanks in advance....
Results 1 to 14 of 14
Originally Posted by xirokxIf in doubt, Google it. -
This could be the fun part. You'd be looking at a graphics card with TV out or if your camcorder has a composite or S-Video Out then you could transfer from PC back to the camera and then to a VCR. As for quality, you'll be bound by the limitations of VHS.
Re: virtual dub to add more footage....
Lets say I wanted to add jpegs (photos) to the beginning of the film, would virtual dub let me do this? and also if I wanted to add chapters i.e. the words chapter 1 blah blah blah, then chapter 2 etc would virtual dub let me do this?
If yes....what software can I use to create the words chapters 1 blah blah blah and more importantly what type of file do I save it as?
Thanks for your help so far?
P.S. Someone told me if I record directly onto a SD card using my digicam I would lose quality is that right? They said the quality would be awful? What do you think?
Thanks -
hey thanks for all your helpful advice
Why supply a SD card with a camcorder if the recording quality is crap hmmmm
Presumably I can cut part of the video footage I dont want also using virtualdub??
Is virtualdub freeware? -
can you advise me on a gfx card i need to be able to do this?
Do I just need to ensure the gfx card has tv out? -
how many "mb's" on average would be taken up if I converted 45 - 1hr's worth of video footage from a minitape on a camcorder to my hdd?
How can I go from PC directly to VHS? What equiment and software would I need? I have tv out on my gfx card...
Enable TV Out in your video card config. Play video in application that has a full-screen mode. Press Record on VHS player. So long as you have the right cable(s) that's all there should be to it.
Which application can I use? Preferably freeware.......What cables do I need? The red, white and yellow cables? Surely the tv out would take care of the sound etc?
Lets say the footage on the pc is of dvd quality whilst transferring will I lost quality?
Please clarify??
Also if I wanted to perform the same operation but needed the VHS to be NTSC does it get complicated?
Please help
Thanks -
thanks mate.....you have been like a breathe of fresh air
I'm very grateful for all your help and advice....
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 20:55 -
DVD authoring/editing questions from a total n00b
By DesertAvenger in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2009, 12:39 -
Live TV streaming to Web via VLC - Total n00b, so go easy on the flames...
By br3nton3 in forum Newbie / General discussionsReplies: 9Last Post: 2nd May 2009, 16:24 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 12:24 -
N00b question: Is re-encoding useless?Need some advice....
By DavidHazelnut in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2007, 19:43
