I use avi files - i know they come in different bitrates but for a 700mb avi on my comp. it took about 1.5 hours to process and burn thru s2d,
then for the same size file it began to take 3 hours, then stretched to 5 hours !!!
my cpu temp reaches 35 deg C. - no dust on the heatsink, fresh grease on the cpu
nothing changed in the comp.
anyone had this before
i run intel pent.4 2.0ghz
1 gig 400mhz ram
46 gig free on HDD
Results 1 to 13 of 13
The size of your sources is not important... The duration is. What are the durations of the three runs? Are you doing anything different between the runs (2 pass/pal->ntsc/ntsc(film)->ntsc)?
My last project was a 43min avi which took 4 hours to process (in the past its been atleast half this time) i have noticed that it has been doing ntsc(film) to ntsc as with my other projects
I only have pulldown ticked in the video encoding options
and in the audio options, i have mpeg audio checked + keep audio if ac3 + keep audio if 48 mpeg audio. -
on secong thought - i dont remember if i was using pulldown before but im pretty sure that i wouldnt have unchecked it if it was checked thru defalt.
ok. Have you got some logs to compare?
stupidly i deleted the badger IT folder when i upgraded to v.2294
Ill get a few logs underway then might get you to have a look at them
Ill re-post when logs are available
thanks chrissy boy -
here is one log that took 4 hours to process a 43min avi
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.1
Version: 2.1.2294.24198
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.49 MB
Executable size in bytes: 2617427
Executable CreationTime: 4/13/2006 4:59:18 AM
Executable LastWriteTime: 4/25/2006 8:36:37 AM
Executable LastAccessTime: 4/25/2006 8:36:51 AM
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 735 MB
Free Physical Memory: 446 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: ECS
Computer Model: P4S5MG/GL+
System Type: X86-based PC
Computer Name: MABALZRH-F44CF8
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: MABALZRH-F44CF8\obiwan
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 2.00GHz
Description: x86 Family 15 Model 2 Stepping 4
CPU Speed: 1.991GHz
CPU FSB: 100MHz
L2 Cache Size: 0 bytes
***************************** Time Zone ****************************
Time Zone: (GMT+09:30) Adelaide
****************************** VIDEO *******************************
Name: SiS 650_651_M650_740
Processor: SiS 650 Rev 00
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 32.0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 52.4 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 28.9 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="4/25/2006 6:09:24 PM" Filename="NONE"><AssetSet><Asset ID="fbf002f2-285d-46fa-a049-3c20975e5af7" Path="C:\Program Files\mIRC\download" Filename="Greys Anatomy - Under Pressure.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="Greys Anatomy - Under Pressure.avi" AssetID="fbf002f2-285d-46fa-a049-3c20975e5af7" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="C:\Program Files\mIRC\download" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="True" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="CopyToDVD" DVDDrive="PIONEER DVD-RW DVR-107D" NeroWriteSpeed="Max" Eject="False" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 350 MB
file=C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure.avi
FormatName=avi
Num_Frames=61778
DurationInSecs=2576
Duration=00:42:56.3
VideoCodec=mpeg4
Width=608
Height=336
Standard=NTSC (Film)
BitRate=1139
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
AVI2MPG: 7800kbs Full-D1
18:09:24: Looking for AVI PAR...
Pass 1/1: Processing Greys Anatomy - Under Pressure.avi
18:09:25: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
18:09:25: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
18:09:25: libavutil version: 49.0.0
18:09:25: libavcodec version: 51.4.0
18:09:25: libavformat version: 50.2.1
18:09:25: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
18:09:25: Input #0, avi, from 'C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure.avi':
18:09:25: Duration: 00:42:56.3, start: 0.000000, bitrate: 1139 kb/s
18:09:25: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 608x336
18:09:25: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
18:09:25: Output #0, dvd, to 'C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2D.mpg':
18:09:25: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 7800 kb/s
18:09:25: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
18:09:25: Stream mapping:
18:09:25: Stream #0.0 -> #0.0
18:09:25: Stream #0.1 -> #0.1
20:27:02: video:1620796kB audio:70446kB global headers:0kB muxing overhead 1.832020%
20:27:02: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Greys Anatomy - Under Pressure_S2D.mpg
20:27:03: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
20:27:03: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
20:27:03: libavutil version: 49.0.0
20:27:03: libavcodec version: 51.4.0
20:27:03: libavformat version: 50.2.1
20:27:03: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
20:27:03: Input #0, mpeg, from 'C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film).mpg':
20:27:03: Duration: 00:42:55.9, start: 0.500000, bitrate: 5477 kb/s
20:27:03: Stream #0.0[0x1e0], 23.98 fps(r): Video: mpeg2video, yuv420p, 720x480, 7800 kb/s
20:27:03: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
20:27:03: Output #0, rawvideo, to 'C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film).mpv':
20:27:03: Stream #0.0, 23.98 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 7800 kb/s
20:27:03: Output #1, mp2, to 'C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film).mp2':
20:27:03: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
20:27:03: Stream mapping:
20:27:03: Stream #0.0 -> #0.0
20:27:03: Stream #0.1 -> #1.0
20:33:19: video:1620798kB audio:70446kB global headers:0kB muxing overhead -4.165327%
20:33:20: NTSC(Film)->NTSC: Applying Pulldown Greys Anatomy - Under Pressure_S2DNTSC(Film).mpv
20:33:21: SVCD2DVD: Convert2NTSC: Converting....
21:31:11: NTSC(Film)->NTSC: Muxing Greys Anatomy - Under Pressure_S2D.mpg
21:49:11: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
21:49:11: INFO: [???] File C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
21:49:11: INFO: [???] File C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film).mp2 looks like an MPEG Audio stream.
21:49:11: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
21:49:11: INFO: [???] Found 1 audio streams and 1 video streams
21:49:11: INFO: [???] Selecting dvdauthor DVD output profile
21:49:11: INFO: [???] Multiplexing video program stream!
21:49:11: INFO: [???] Scanning for header info: Video stream e0 (C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film)_pd.mpv)
21:49:11: INFO: [???] VIDEO STREAM: e0
21:49:11: INFO: [???] Frame width : 720
21:49:11: INFO: [???] Frame height : 480
21:49:11: INFO: [???] Aspect ratio : 16:9 display
21:49:11: INFO: [???] Picture rate : 29.970 frames/sec
21:49:11: INFO: [???] Bit rate : 7800000 bits/sec
21:49:11: INFO: [???] Vbv buffer size : 229376 bytes
21:49:11: INFO: [???] CSPF : 0
21:49:11: INFO: [???] Scanning for header info: Audio stream c0 (C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2DNTSC(Film).mp2)
21:49:11: INFO: [???] MPEG AUDIO STREAM: c0
21:49:11: INFO: [???] Audio version : 1.0
21:49:11: INFO: [???] Layer : 2
21:49:11: INFO: [???] CRC checksums : no
21:49:11: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
21:49:11: INFO: [???] Frequency : 48000 Hz
21:49:11: INFO: [???] Mode : 0 stereo
21:49:11: INFO: [???] Mode extension : 0
21:49:11: INFO: [???] Copyright bit : 0 no copyright
21:49:11: INFO: [???] Original/Copy : 1 original
21:49:11: INFO: [???] Emphasis : 0 none
21:49:11: INFO: [???] SYSTEMS/PROGRAM stream:
21:49:11: INFO: [???] rough-guess multiplexed stream data rate : 8195200
21:49:11: INFO: [???] target data-rate specified : 10080000
21:49:11: INFO: [???] Setting specified specified data rate: 10080000
21:49:11: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
21:49:11: INFO: [???] New sequence commences...
21:49:11: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
21:49:11: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
21:49:11: INFO: [???] STREAM e0 completed @ frame 61768.
21:49:11: INFO: [???] STREAM c0 completed @ frame 107345.
21:49:11: INFO: [???] Multiplex completion at SCR=231874998.
21:49:11: INFO: [???] Video e0: buf= 0 frame=107331 sector=00821472
21:49:11: INFO: [???] Audio c0: buf= 2016 frame=107345 sector=00035712
21:49:11: INFO: [???] VIDEO_STATISTICS: e0
21:49:11: INFO: [???] Video Stream length: 1659696724 bytes
21:49:11: INFO: [???] Sequence headers: 3690
21:49:11: INFO: [???] Sequence ends : 0
21:49:11: INFO: [???] No. Pictures : 61769
21:49:11: INFO: [???] No. Groups : 3690
21:49:11: INFO: [???] No. I Frames : 3690 avg. size 44150 bytes
21:49:11: INFO: [???] No. P Frames : 16901 avg. size 32911 bytes
21:49:11: INFO: [???] No. B Frames : 41179 avg. size 22839 bytes
21:49:11: INFO: [???] Average bit-rate : 5153600 bits/sec
21:49:11: INFO: [???] Peak bit-rate : 10713600 bits/sec
21:49:11: INFO: [???] BUFFERING min 15 Buf max 209892
21:49:11: INFO: [???] AUDIO_STATISTICS: c0
21:49:11: INFO: [???] Audio stream length 72136512 bytes.
21:49:11: INFO: [???] Syncwords : 107346
21:49:11: INFO: [???] Frames : 107346 padded
21:49:11: INFO: [???] Frames : 0 unpadded
21:49:11: INFO: [???] BUFFERING min 15 Buf max 683
21:49:11: INFO: [???] MUX STATUS: no under-runs detected.
21:49:11: Done: Processing assets for DVD creation
Authoring DVD Folders
21:49:11: Creating TitleSet # 1
21:49:12: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
21:49:12: -->: DVDFolders creating VTS
21:49:12: -->: VTS 01
21:49:12:
DVD Folders: Processing C:\Program Files\mIRC\download\Greys Anatomy - Under Pressure_S2D.mpg...
21:53:28:
21:54:26:
21:54:26: Finalising DVD...
21:54:27: SVCD2DVD: DVDfolders
21:54:27: -->: DVDFolders creating table of contents
21:54:27: scanning C:\Program Files\mIRC\download\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
21:54:27: Finalising DVD...Done
21:54:27: Done: Authoring DVD Folders -
maybe you need a second HD, as you are converting from C: to C:
source C:
temp C:
target C:
and I donīt think you will get improve if you encode from C: to D:, as I think actually you had a 120GB HD, Am I wrong? -
Do you defrag frequently?
Ok, so now try to defrag as ChrissyBoy said, and also try to create your projects from C: to D: or vice versa.Originally Posted by have mercy
will do guys,
thanks for the support,
does processing an asset from one drive to the other realy save time or is it just a thought !! -
It will always save time. One drive reads, the other writes as opposed to a single drive having to switch back and forth.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Anybody experienced with ADVC-300 use ?
By Tafflad in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2009, 04:33 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
DV - avisynth - x264 your experienced thoughts
By doggyjumper in forum Video ConversionReplies: 0Last Post: 29th Aug 2008, 14:41 -
Burn Times 3x longer after I installed AutoGK
By Gunewbie in forum ComputerReplies: 6Last Post: 19th Jul 2007, 22:45
