Help I am trying to load a 4gig and a 1.9gig avi file to convert to mpg but the loading process stops at 8889. Is there a limit to the size of file that can be loaded into the program?
Thanks.
Whao, that's big. I've load 1GB files before. I would suggest that you try frameserving your file w/ AVIsynth to TMPGenc, that should fix it (will slow down encoding very slightly).
MeGUI: Problem calculating AVI file size
By fakecake in forum Newbie / General discussionsReplies: 9Last Post: 1st Feb 2009, 08:11 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 11:51 -
AVI File Size problem
By prcole18 in forum Capturing and VCRReplies: 5Last Post: 14th Jul 2008, 18:05 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
