ok I have a file that I created from a DV camera on my computer and I have run it through TMPGE to get it to it's elementary streams.
I've run the thing through both DVDAuthorGUI and TMPGE DVD and I keep getting the same result.
The DVD starts off really slowly (The voices and footage are in slow motion, that really deep sound when you play a 78 at 33 1/3 [btw if you know what I'm talking about here you get a cookie]) then goes to normal, then back down to slow motion.
I've checked everything up to the authoring and everything plays perfectly, it's only after I take it through either authoring program that the slow motion thing occurs.
I've tested the ISO files by using VLC and an Image Drive as well to make sure that it's not my DVD burner or DVD players and I keep getting the same slow down and speed up.
What the heck is wrong?!
Ugh... I keep forgetting which is my main account here...
If you could please respond to the message using the reply for this nickname it should work... I need to figure out how to get smoeone to delete that other account.It's not the fall that hurts it's the sudden stop -
Yes the mp2 and m2v files played perfectly.
Once they were converted to the vob files by DVDAuthorGUI and TMPGEnc DVD Author there was a problem with teh video slowing down and speeding back up to normal every few moments.It's not the fall that hurts it's the sudden stop
TMPGEnc Authoring Works v4 – weird warning.
By redpol in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 08:05 -
Weird subtitle colors when authoring a DVD
By dexter30 in forum SubtitleReplies: 4Last Post: 22nd Feb 2010, 21:54 -
weird subtitle error during authoring of a DVD
By michcio in forum SubtitleReplies: 2Last Post: 26th Oct 2008, 07:11 -
Weird Audio problems....
By Superstar24 in forum Newbie / General discussionsReplies: 10Last Post: 15th Jun 2008, 20:19 -
Slow FPS and weird sound problems
By desantnik in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 13th Dec 2007, 16:33
