when I go to compile my project I get this (I tried re-installing, running anti virus & spyware programs, using another drive
and restarting and all that) I've been using DVD-lab Pro for a good long time now and this is the first time this has happened
It looks like you're running out of space.
Your output and temp directories are on the same hard drive and you have less than 8GB free. You are making a full DVD so you need 4GB for the finished DVD, and 4-8GB for the temp files (as it works). That's too much.
Clean up a bunch of space and try again. Or get an external 100GB+ drive (less than $100). I've heard that it's not a good idea to have the output and temp directories on the same drive.
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 01:07 -
Advice needed on adding Windows Password to Admin
By ahhaa in forum ComputerReplies: 2Last Post: 20th Jul 2010, 01:26 -
how to run as admin in CMD in Windows XP?
By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 29th Jan 2010, 19:26 -
odd frame rate problem
By deadrats in forum Video ConversionReplies: 0Last Post: 7th Dec 2008, 14:32 -
Odd Windows Error
By Poppa_Meth in forum ComputerReplies: 9Last Post: 6th Dec 2008, 13:18
