Ok - I have read thread after thread but I am still confused.
I have a canon s450, it generates avi files - they seem to be "not standard" by default - can't play them in win media player - only in quicktime
Cant open them in camtasia studio, cant open them in windows movie maker, etc.
Any ideas here on what I can do to get these files converted to mpeg or something usable?
Thank you,
Allen
Results 1 to 15 of 15
what is the video codec? identify with mediainfo,gspot,avi2clipboard.
and try convert with super, it supports everything. -
If you use VirtualDub, it has a built in MJPEG decoder. Otherwise install one. ffdshow is free and can decode MJPEG.
Originally Posted by allen074
I did not have problem with Canon avi. I converted a few canon 640x480 avi files for friends from ( A610, A520 ) with TMPGenc, to DVD mpeg2, and put them on DVDR. -
when i open the file in virtualdub - it says the following:
video codec "panasonic dv codec" is claiming to be able to decompress formats that it does not actually support. This can cause the Windows video codec system to malfunction and may cause applications to crash. Please remove the errant codec or replace it with an updated version from the original vendor.
how do you remove a codec and should i remove it?
thanks! -
See if it's in add/remove programs if you want to remove the Panasonic codec. You can always put it back. It's used commonly for opening and encoding DV files with Virtualdub.
You could try SUPER for conversion of the MJPG to another format. It handles most formats. I've never had any problems opening the AVIs from my Canon 400 still camera in VirtualDub. -
btw - i have tried removing the panasonic codec 10x now (seriously) -- it keeps coming back!
man i am so frustrated right now
i downloaded "morgan codec" - appeared to allow the file to open in virtualdub - saved out an avi - 1.2gig for a file that was 45mb.
then tried making a mpg - it makes it, but wont open it says no codec
i just dont get it -
You have TMPGENC, and Microsoft movie maker is part of XP. I managed to convert a SD450 avi clip into DVD mpeg2. You should able to do the same with the same tools.
Canon avi is compressed. DV avi is lossless compressed. DVD mpeg2 is compressed. I got only 1 to 2 expansion from Canon avi(8mb) to DV avi(16mb). -
Panasonic DV is bad. It will accept any FourCC which breaks VfW since the way VfW works is that it checks for something registered for a particular FourCC, then if nothing is found checks to see if anything else will accept. So you may very well have a compatible decoder installed, but Panasonic takes over. There are other DV codecs.
well i cant seem to remove it
everytime i try - even if i reboot - it comes back
do you know hot to remove perm?
thanks
Advice needed on issue with AVI screen ratio
By Ric76 in forum EditingReplies: 4Last Post: 10th Aug 2010, 06:30 -
Going from avi to flv, generated file is empty
By jearbear in forum ffmpegX general discussionReplies: 2Last Post: 15th Jun 2008, 17:05 -
File conversion or Frontpage issue?
By ANDREWBALK in forum Video ConversionReplies: 1Last Post: 6th Aug 2007, 10:55 -
CUCUSOFT file conversion issue
By steve7510 in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 08:21 -
By steve7510 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 21:05
