Using Shrink than dvdauthorgui I end up inserting Vobs into authorgui. First vob has nav packs Vob1 rest of vobs 2,3,4 no nav packs. Rather than demux is there a step saving way to get the nav packs into the other vobs?. To overcome this I use an older version of authgui that does not check for nav packs and that usually gets around the problem. Works just fine but sometimes get the error message backward SCR or something like that so it those cases it won't work.
Any easy work around?
How to get rid of this nav bar
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2012, 20:40 -
RipIt4Me "Packs Removed" -- What are the "packs"?
By CobraPilot in forum DVD RippingReplies: 3Last Post: 7th Dec 2009, 11:04 -
dvdauthorgui nav cmds/call menu to different menus?
By ecc in forum Authoring (DVD)Replies: 4Last Post: 23rd Jan 2008, 21:58 -
Clonedvd2 message:NAV error in VOBU,help!
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 03:04 -
What author tool besides GUI For DVDAuthor for mpeg2 files w/o Nav Packs?
By palouse in forum Authoring (DVD)Replies: 7Last Post: 27th Jun 2007, 05:44
