I'm lost.
I have a LG 1920P Flatron LCD with both VGA in and DVI-I in.
I have an ATI All In Wonder 7200 AGP card (called "DDR32" at the time). According to ATI it has "DVI-I output (VGA monitors connect through DVI-I to VGA adapter - AGP version only)"
The LG came with a DVI cable. It may be a DVI-D, not really sure. It doesn't say.
When I plug the DVI cable into the ATI, I get a blank screen, no picture.
What's wrong? Do I need a DVI-I cable?
Results 1 to 11 of 11
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
DVI-I is both analog and digital and connects to either
maybe you have the wrong refresh rate on the ati -- set it to 60hz or whatever LG says .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I think my cable is a DVI-D. But wouldn't that still work? Since both the card and the monitor do DVI digital.
I'll try to mess around with refresh rates, as soon as I can locate my cable again. I put it aside some weeks ago, didn't have time to fool around with it. Now I do.Want my help? Ask here! (not via PM!)
DVI-I has both DVI-D (digital) and VGA (analog) pins. Maybe this monitor only uses the analog pins since it also has a VGA connector.Originally Posted by lordsmurf
http://en.wikipedia.org/wiki/DVI -
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Thanks for the info. More reading to do.
Not sure if this applies - different AIW card and display type - but FWIW......
When I first connected my AIW 9800Pro to my Sony TV via DVI, WinXP did not initially detect the new monitor and defaulted to "Default Monitor". This setting resulted in a black/blank screen.
After a reboot or two, the "Default Monitor" setting began working (poorly). In Display Properties|Settings, a new monitor choice appeared (Sony TV), but was not selected.
Manually changing the monitor to "Sony TV" may have improved display quality somewhat, but I had other issues regarding screen resolution - outside the scope of this discussion.
Perhaps a cold boot is necessary for the detection of some monitors. -
Well, I have the LG drivers installed already, and have been operating with VGA connections for a couple months now. So not sure if what you just said applies, but thanks all the same.
I had been using the 9800Pro with the VGA adapter for a couple of months, although I was connecting it to a Sony MultiScan CPD-E540, not the Sony TV.
WinXP just didn't detect the new monitor for the first few bootups.
Does the same monitor with a different connection type = a new monitor to WinXP or the display drivers?
VGA and DVI can't be too terribly different if a small adapter can change one to the other. -
Another thought /question - I hope I'm too far not off the deep end here.
Just because the manufacturers in question (LG and ATI) use a DVI-I connector, does it mean that the devices must use/have present both analog and digital signals? DVI-I can contain both, but does it have to?
If the design idea of the LG was VGA for analog only and DVI-I for digital only - and the AIW only outputs on the RGB pinout, then you would get the behavior that LS is experiencing.
I always assumed that there was a digital signal in the DVI-I output of my AIW 9800Pro card but I can't verify it. I reviewed the docs and it isn't mentioned explicitly.
I can't find a link to the LG LCD manual. -
The AIW will have analog and digital pins avaialble as DVI-I. The device at the other end of the cable may respond to only the DVI-A (similar to VGA) pins or DVI-D (digital) pins. If the cable is DVI-D only, the analog signal woun't be carried.Originally Posted by dLee
see: http://en.wikipedia.org/wiki/DVI
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Resolution mismatch connecting PC (DVI-I) to LCD TV (HDMI)
By anoopaythala in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Feb 2009, 11:48 -
Problem connecting computer (DVI) to TV (HDMI)
By kizzad in forum DVB / IPTVReplies: 2Last Post: 14th Jan 2008, 21:52 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 07:49 -
Query about connecting VGA outputs to DVI inputs
By aceizace in forum DVB / IPTVReplies: 4Last Post: 19th Sep 2007, 16:00
