I have a Pinnacle PCTV Pro tv tuner card installed in my pc for many years. I have captured many clips using it. My pc is able to capture upto dvd resolution (720x576).
About a month ago I formatted my hdd and reinstalled everything. If I install PCTV v5.5 then all capture modes viz. vcd, dvd, divx, mpeg1, 2 etc are all available. But if I install the PCTV v5.75 update then only mpeg1 capture mode is available. All other capture formats are greyed out. I have been using the v5.75 update ever since I downloaded it from Pinnacle's website. Now suddenly there is this problem.
DVD, divx codecs are installed because I can playback these videos without trouble. What can I do to solve this? I dont want to use PVTC 5.5 because its interface is slow.
Try this link on how to install the update.
http://webboard.pinnaclesys.com/read_messages.asp?WebboardID=1&ForumID=-999&SectionID=...hread=33&lng=1 -
I tried the above method, it didn't work. Just uninstalled the newer version and reinstalled the older version. Guess what? I can capture tv programs in dvd resolution! But I will be damned if I can get the newer version to capture anything above mpeg1 resolution. And to think that I have been using this for almost 4-5 years. I am at my wits end about this!
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 20:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
I need a program to capture Pinnacle HDTV Pro Stick
By hpcampr in forum Capturing and VCRReplies: 8Last Post: 24th Jan 2008, 17:32 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 18:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 23:40
