I need to take several DVDs and rip just portions of them to compile onto one DVD. I've read through the forums, and saw some options, but I was concerned with lack of quality. I've looked at the program FlaskMpeg, but there seems to be quality loss. What's the best way to take out a couple scenes from a dvd and what is the best format to save it to without losing quality?
Thanks!
Use DVD decrypter to rip just the chapters that contain the scenes you need - no quality loss
Edit these down with an mpeg editor that doesn't encode, or only encodes a few frames around the cut - no quality loss (or so little you won't see it)
Assemble the pieces in TDA as a single track for smooth play through - no quality lossRead my blog here.
Doesn't DVD Decrypter only rip to a Vob file? TDA can do the editing as far as trimming what I don't need?
TDA doesn't change anything to mpg - it takes mpg or VOB as source, then spits out Video DVD files including (but not limited to) VOBs. As TDA can't encode, no quality loss is involved.
/Mats -
Actually you can use TDA to rip vob's from a disc to .mpg'sOriginally Posted by mats.hogberg
Along with everything else you said 8)
DVD ripping: does DVDFab give the best picture quality?
By Tom80112 in forum DVD RippingReplies: 25Last Post: 21st Feb 2010, 06:24 -
DVD Ripping, editing and Reburning with Maximum quality
By reccos in forum MacReplies: 5Last Post: 16th Nov 2009, 10:19 -
By reccos in forum MacReplies: 1Last Post: 16th Nov 2009, 09:30 -
Ripping a DVD to 700mb and getting the best possible quality ?
By tadrian in forum DVD RippingReplies: 1Last Post: 24th Aug 2008, 05:04 -
Ripping a portion from a music file
By Shadowofthedarkgod in forum AudioReplies: 7Last Post: 17th Jul 2008, 15:09
