I'm trying to convert a AC3 audio 23.976 FPS to a AC3 audio 25FPS using Besweet
here is the command line :
besweet.exe -core( -input "F:\DVDMOVIE\audio.ac3" -output "F:\DVDMOVIE\audio_fix.ac3" ) -ota( -r 23976 25000 ) -ssrc( --rate 48000 ) -ac3enc( -b 256 -6ch )
And I get this error - LOTS OF THEM :
[00:21:53.200] W7: Downmix overflow (0: +0.4dB)
[00:21:53.205] W7: Downmix overflow (2: +0.9dB)
[00:21:53.210] W7: Downmix overflow (2: +0.7dB)
[00:21:53.216] W7: Downmix overflow (2: +0.8dB)
[00:21:53.221] W7: Downmix overflow (0: +0.3dB)
[00:21:53.226] W7: Downmix overflow (2: +0.7dB)
[00:21:53.232] W7: Downmix overflow (1: +0.4dB)
[00:21:53.237] W7: Downmix overflow (2: +0.1dB)
[00:21:53.242] W7: Downmix overflow (1: +0.1dB)
[00:21:53.248] W7: Downmix overflow (2: +1.0dB)
[00:21:53.253] W7: Downmix overflow (0: +0.5dB)
[00:21:53.258] W7: Downmix overflow (0: +0.5dB)
[00:21:53.274] W7: Downmix overflow (2: +1.2dB)
[00:21:53.280] W7: Downmix overflow (2: +0.9dB)
[00:21:53.285] W7: Downmix overflow (2: +0.6dB)
[00:21:53.290] W7: Downmix overflow (1: +0.8dB)
[00:21:53.296] W7: Downmix overflow (2: +0.3dB)
[00:21:53.301] W7: Downmix overflow (1: +0.6dB)
[00:21:53.312] W7: Downmix overflow (2: +0.4dB)
[00:21:53.322] W7: Downmix overflow (0: +0.5dB)
[00:21:53.328] W7: Downmix overflow (1: +0.8dB)
[00:21:53.333] W7: Downmix overflow (1: +0.8dB)
[00:21:53.338] W7: Downmix overflow (0: +0.3dB)
[00:21:53.344] W7: Downmix overflow (2: +1.2dB)
Why this ?
can someone help ?
256 is awful low bitrate for 6ch
you have to turn "auto find maximum gain" off and find the max gain yourself . though anything less than 3 is not really audible .... specially since ac3 is rather major lossy anyway .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
5.1 to 2.0 Downmix Script - Check It Out
By Soopafresh in forum AudioReplies: 19Last Post: 26th Aug 2011, 04:49 -
DTS Downmix?
By therock003 in forum AudioReplies: 5Last Post: 22nd Apr 2011, 20:28 -
Will PS3 properly downmix 5.1 AAC to 2.0 Stereo ???
By FulciLives in forum Media Center PC / MediaCentersReplies: 1Last Post: 11th Oct 2009, 08:58 -
DVD on computer, no speech, How to downmix AC3 5.1?
By Perro in forum AudioReplies: 4Last Post: 8th Mar 2009, 03:29 -
After downmix audio video sync problem
By adarkenigma in forum Video ConversionReplies: 7Last Post: 17th Oct 2007, 09:10
