Ive tried and tried, first i used dvddecrypter to rip and then shrink and wouldnt work, then i tried ripping with dvdfab decrypter and then shrinking and i get this message dvd shrink has encountered a error and cannot continue failed to read file "c/dvd/video_TS/VTS_01_1.vob" Invailed access to memory location. I tried doing a search on here but couldnt come up with solutions that i could understand, if you can please help me or know of another program to use i would appreciate it, thanks in advance for any help.
Results 1 to 12 of 12
You could try running FixVTS on the DVD Fab Decrypter output to see if that fixes the problem. Otherwise try using the latest DVD Fab Decrypter. It is being constantly updated and you need to keep up if that is your tool of choice.
Read my blog here.
the version i have was last updated 4/12/06 i believe, but i will try your idea, thanks!
VitxVTS was written to try to repair DVD Fab Decrypter output for DVD Shrink to read.
Read my blog here.
Get the latest DVDFAB DECRYPTER then use that to rip to your hard drive then use DVDSHRINK.
dled and installed the newest version of dvdfab decrypter, and it still didnt work, i really could use some help backing up this movie, thanks.
I had issues ripping it with Decrypter on my main computer. Everything worked fine except 1 VOB. I have a DVD-r and a separate DVD Rom, neither would rip..
My solution was to use a 3rd dvd rom. Ripped the VOB successfully on my laptop. I also found that DVD Shrink would fail on opening up files, but DVD2One worked successfully.
I know some might not have the options that I had, but this is what worked for me successfully.
It is possible to rip this movie, I just had to be a little creative.
Hope this helps... -
well i give up, i cant get madagascar to work and i cant get shopgirl to work , i ripped both with dvdfab decrypter and tried fixvts to cleanup or repair the vob files then shrink and it still wont work, i give up.
My very 1st HDV burn to dvd/need advice please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 16th Jul 2010, 01:51 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39
