Hi everyone:![]()
I am adding subtitle to my AVI file, using VirtualDubMod. This means that I will have to use the software's "Full Compression" mode.
Besides DivX 5.2.1 codec, is there any better codec?
Results 1 to 10 of 10
better for what ? playback ? storage? size ? speed ? etc ?
Hi, I think for all of those those criteria.
I am working on an AVI file which is a little longer than usual.
I added subtitle and created a new AVI, using DivX 5.2.1. When I converted the new AVI to DVD, the total size exceeded 4.7GB. I had to use DVDShrink to fit it on a single-layer DVD. The video quality suffered because from the orginal AVI file, it already went through 2 encodings: the first encoding when I added the subtitle and the second when I shrank it.
Therefore I am looking for a best possible codec to use when I add the subtitle so that when I shrink the file, the video quality won't be so bad. -
dont create a new avi file is best solution -- add subtitles and frame serve to mpeg2 encoder
use a bitrate calculator to calculate bitrate so you dont go to large"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hi! Will I still be using VirtualDubMod? If not, which software are you refering to?add subtitles and frame serve to mpeg2 encoder
Search for frameserving and virtualdub in the guides section. You will find guides on setting up virtualdub to frameserve
Read my blog here.
And if you frameserve, you can use a lossless codec like Huffy to minimise losing quality.
Thank you for all of your help.
This frameserving is new to me (naturally, since I am a newbie!
). I will spend sometime digest it.
Cheers
v210 AVI codec
By christianolovesvideo in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2009, 14:59 -
DV-avi codec error????
By crb119 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Jun 2009, 07:49 -
DVD to AVI but no codec
By Cazz in forum DVD RippingReplies: 6Last Post: 27th Mar 2009, 10:10 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 20:13 -
The best AVI video codec
By hzgg2 in forum Video ConversionReplies: 1Last Post: 2nd May 2008, 17:19
