Hello,
I recently bought a new computer with a clean installation of Windows XP Home sp2. The computer is a dualcore 2.4 Intel
Installation of svcd2dvd also went fine. I went online to register, no problem at all.
However, the first time i wanted to use it, it did not work and still does not work.
when i want to start it up, I see (using task manager) that the process is starting but then, after a few seconds, it stops again without any notice.
I tried starting up the demo and register again but I now have the "limit reached" notification.
To try to solve the problem I did a re-installation. I now get stuck at the registration process. Apperantly the licence key does not recognize this is the same computer ?
Any idea what might be the best way to solve this problem ? It looks like the licenceses need to be reset but did the "not starting up" also have to do with this ?
Greetings,
Henri
ps: message send to rerequest.
Do you have .net installed on the new PC?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Hello Jikchung,
I think I have.... It does not show up anymore with windows update and I do have a directory inside the windows directory called Microsoft.net
I however do not see it with software.... So i have no idea how to check.... -
Go to "control panel" and see if it's listed under "add/remove programs".
Dwight
- Herm Albright
Yep, it's there.
Called Microsoft.net Framework, the hotfix (KB886903) and also the Dutch Language Pack.
greetings -
Hello,
The license count has been reset and I redid the registration. Now it works again. No problem with startup.
I can only think of 2 things that went wrong....
1) At the end of the registration proces there are 2 buttons. One for "register" and another for "exit". Can it be that the first time i pressed "exit" ? I pressed register now.
2) During installation of some other program something got messed up.
I have no idea but I am happy it works again. Alway's loved the software and as everyone can see help in the forum is alway's great.
Thanks very much !!
greetings
No POST during startup
By mysts in forum ComputerReplies: 5Last Post: 25th Oct 2011, 02:47 -
XP OS selection at startup.....
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 01:55 -
Fatal Error on Startup SVCD2DVD 2.5 (CRASH)
By jenevans33 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 16th Mar 2008, 11:06 -
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 06:14
