You mean burn data files of mp3's with a standalone unit?? I don't think a thing like that exists. Most would be strictly dvd video burners or audio music burners (standard 80minute cd recorders not mp3 based).
Results 31 to 44 of 44
I think you are all missing the point of the original person who suggested that this may be an option.Originally Posted by ark
With the appropriate software, you can speed up or slow down a section of audio but to preserve the pitch - so that you don't get the "chipmunk" effect. Unless you listen to two things side by side, most people won't actually notice audio that is sped up by a few percent.
Regards.Michael Tam
w: Morsels of Evidence -
From 90 minutes to 80 minutes, this represents a reduction of speed (or tempo) of +11%. Imagine each song now lasts only approximately 90% of the intended length. To me, that's significant.
ADS makes the ADS Instant Music which is a computer device.Originally Posted by devdev
This small "box" connects to your computer via the USB port. You can then connect any audio source to it and it will record to your computer in MP3 format. After that you can burn to a CD-R disc and thus create a MP3 CD-R that any MP3 capable CD player can play.
This seems to me as though it would be the easiest way to go about it.
Just make sure you use CBR encoding when doing MP3 and try to use a bitrate of at least 192kbps or higher.
If my math is correct then a standard 700MB/80min CD-R can hold something like 7 1/2 hours of MP3 music at 192kbps ... even if you use the highest bitrate that MP3 can use (which is 320kbps) you are still talking about 4 1/2 hours per CD-R disc.
Hi everyone:
I would like to demonstrate how a 10% reduction in speed (not pitch) affects an audio recording. Please listen to the 2 audio clips below. They are the same piece, except one was digitally adjusted to be 10% shorter than the other. The pitch stays unchanged.
Original: http://20-248-a.onlinestoragesolution.com/ciaobellavn/public/sonatine%20-%20unchanged.mp3
Changed: http://20-248-a.onlinestoragesolution.com/ciaobellavn/public/sonatine%20-%20changed.mp3
Cheers
p.s.: btw, this is homemade
, no copyright violation here.
I just downloaded them and not knowing what this music is ... I can definately tell a difference between the two.Originally Posted by moviebuff2
I can only imagine that the difference would be even more noticeable with music that I know well.
Definately not at option at least not at a change of 10%
Think of it this way ... PAL video is a 4% speed up from NTSC/FILM and it is barely considered acceptable.
In fact I recently got a PAL DVD of a documentary with narration by William Shatner and the 4% audio speed up was killing me because the William Shatner "dramatic pause for effect" was killed by the 4% speed up (plus it didn't help that I have the same documentary on NTSC VHS and have watched it many times with Mr. Shatner and his pauses at the correct speed). In short even a 4% speed up was enough to destory his performance.
Funny I thought it was just him that destroyed his own performancesOriginally Posted by fulcilives
(sorry for going offtopic I couldn't resist a jab at Shatner
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
"I ... have had ... enough ... of ... you !!!" - William Shatner as Captain Kirk in Star Trek IIIOriginally Posted by yoda313
I have the 90 Min CDRs, but my software/burner does not recognize them as 90 minutes. I have two questions:You are not helping either.
If your burner and software recognize 90 minutes
available....it is NOT overburning. Both my burner
and software recognize 90 minutes available and I
have never used the overburn option to create my
CD's.
1. Is the failure to recognize the corret disk size a problem with the recorder or software or both?
2. If I can't get the system to recognize the proper size, is there any problem with setting it for overburn? i.e. is there any quality difference between setting for overburn and using a "standard" burn for a 90 min CDR?
Thanks,
REBfREBieware- you get what you pay for. -
1) The more and more I read replies(like yours and others)....I'm willing to bet that it is theOriginally Posted by rebarlow
burner's fault first....then software. Someone here even mentioned using Nero with his LG burner...and no mention of overburning with complete success.
2) I also think...in my opinion...that "overburning" is what creates the unplayability in any CD-R....including discs that have a smaller capacity than 90 minutes/800MB...since overburning infringes apon the lead-in (and maybe lead out?) data required by CD players.
Again...the only drive manufacturer that has in the past ever specified that their particular drive will in fact read larger sized CD's properly is LG. The only drive manufacturer that I have ever seen that specified that their drive will NOT read larger sized CD's is Pioneer. The rest of the drive manufacturer's specs simply do not mention anything about it....so we are left to chance/guess.
If you are dead-set on burning 90 minute CD-R's...get an LG. Both my old 4040B and my 4167B read them correcctly....and according to oldfart...his 4163B burns them with Nero.
I burn mine with Prassi Ones. -
Hech-
Thanks for the quick reply. If need be, I probably will try changing out my burner.
You can still find some new 4040B's out there REAL cheap....leftovers and such. LG drives are not expensive anyway....however the 4040B is only 4x and no bitsetting...and single layer only on DVDR.
BUT...a bit hard to find in America from what I've read. -
Just as a follow-up-
I have never been able to get my lite-on/nero combo to recognize the 90 minute discs, but have used overburning up to nearly the full 90 min with success. So far every audio disc I've burned has been playable to the end, even in my car player. Overburning may be a sloppy kluge, but it seems to work for me...
Thanks for the inputfREBieware- you get what you pay for. -
Oh...and my new LG 4167B also recognizes 90 minute CD-R's....just for more info.
recommended bitrate for squeezing out quality of DVD when converting to mkv
By arconreef in forum Video ConversionReplies: 2Last Post: 24th Dec 2010, 16:39 -
MKV, 1:37 long, audio always comes out 44 mins only..
By TheGlow in forum Video ConversionReplies: 6Last Post: 20th Apr 2009, 17:45 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
Is there a filter for reversing "Credit Squeezing" ?
By AlanL in forum EditingReplies: 3Last Post: 9th Apr 2008, 08:39 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
