    Mar 2006
    I open the file and wmp opens. Then it says error downloading codec and it only plays the audio. Was the file downloaded improperly? Its a torrent. I didnt change any settings on bittornado.
    Nov 2002
    Without knowing that codec it used, it's impossible to tell.
    As for how to tell that codec it used... Try YAMB
    USA
    If you want to play it, VLC is a versatile, all around player. If you want to convert it, try SUPER. Both freeware.
    And welcome to our forums.
    Dec 2004
    Australia
    Should be MPEG-4 Part2 or AVC. ffdshow can decode both. MediaInfo can tell you what streams an mp4 contains though.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Could be using H.264 for video, and you don't have a codec/splitter installed for it. If you have Quicktime 7 installed, try opening it in Quicktime's player, to see if it'll open using QT's support. As mentioned above, VLC will also work (probably a good idea, too, if you don't want to risk installing additional codecs just yet (and that includes Quicktime)). As an additional bonus, VLC should probably also be able to tell you more information about the file, such as what codec the file's using for video (which would help us, too. )
    Edit: Ah, celtic_druid beats me to everything. ^_^
    Mar 2006
    Hey what version is everyone using. Tryin to get 8.5 for xp cant seem to find it. Am i passing over it?
    Mar 2006
    Anyway using 8.4 it opens fine. The stream is mp4v.
  8. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Some time back I had the same problem with WMP10 after updating Quicktime. My solution was to downgrade both WMP and Quicktime (I really find it unattractive to use anyway).
