Hello all..
I have many movies in avi format.. i want the movies to be written as DVD. Searched the forum but culdnt get the exact soln..
I need to know which s/w to use to convert these avi files to dvd and then written on a DVD Disc and then played it in a DVD Player.
Tutorials invited.
TIA
-=[ Prepare 2 B Compressed ]=-
There are links to the left that will take you to what you want...
"Tools"
"Guides"
"Convert"There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I generally use TMPGEnc to encode them from .AVI to .MPG, and TMPGEnc DVD Author (they are separate packages) to make a DVD out of the .MPG file. It can also burn it for you.
There are loads of guides under "convert" and "author" on the toolbar on the left-hand side of your screen. You could also search by tool, which is what I generally do.
Good luck! -
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm or convertxtoDVD or DivxtoDVD (free version).
If in doubt, Google it. -
Hi..
I tried to convert my existing AVI files to DVD MPEG2 format using TMPGEnc DVD Author. It is producing a whopping 4 GB movie file for a single movie.
But i have to include 3 movies in a DVD. How should i attain this.
3 movies in a single DVD wil b much better cos i have loads of movies in various formats viz. avi, divx and mpg.
with which s/w should i convert all the format to a dvd compatible format to put in a single dvd.
Help needed at once.
TIA-=[ Prepare 2 B Compressed ]=- -
Read the guides. They will tell you about the marvels of bitrate calculators and other tools that will allow you to achive what you want. Read the What is DVD section, which will tell you how much space you have to play with, and the resolutions you can use. If you want to fit three full length movies, then full resolution will be too high.
As a general rule, an avi will grow to be 3 - 4 times larger when encoded as mpeg 2 to be anywhere near the same visual quality.Read my blog here.
Originally Posted by dre@msIf in doubt, Google it.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
