I notice a considerable amount of loss of quality when rendering my .avi clip to .mpg2 (2 pass best video quality in Vegas)
Is there a better way to turn my avi clips to mpg2 clips with less loss of quality?
thanks
Results 1 to 12 of 12
You shouldn't have that much lose of quality if your bitrate is high enough. Are you resizing too? That can sometimes lead to quality lose. What format of AVI are you starting with?
What sort fo AVI ? Is this downloaded low res, ultra-compressed video, ot DV avi from your own camera ?
What are you doing to the avi ? Filters, resizing etc ?
What bitrate are you using when you output from Vegas ?
Describe the quality loss as you percieve it - is it soft, are there artifacts ? What are you seeing ?Read my blog here.
Simple question: Is there a better way to turn my avi clips to mpg2 clips with less loss of quality?
Simple answer: Yes.Want my help? Ask here! (not via PM!)
So which way is better papa smurf?
720 x 480, the original AVI was created from using decrypter to extra the clip from a dvd, then import the .vob to VirtualDub and then save as .avi using HuffUV -
I agree, quality sources should use higher average bitrate if quality is the main concern. Dual layer DVD-9 media solves the length issue.
The MPeg2 decompression to Huffyuv and re-encode will degrade the image somewhat. I trust your Vegas project setting was uncompressed "NTSC Standard (720x486, 29.970 fps)"*. If you had DV as the project setting, there would have been an additional unnecessary compression.
If filtering+effects wasn't the goal, better results would be obtained using a MPeg2 native editor with "smart" encoding. That would preserve first generation quality for the unfiltered frames.
* with 486 changed to 480 for DVD or ATSC sources. Or for a progressive DVD it would be 23.976 uncompressed 720x480.
Loss of quality when uploading video
By Riff88 in forum Video ConversionReplies: 2Last Post: 17th Mar 2012, 12:40 -
How to add selectable audio to a video without quality loss
By m.eshi in forum EditingReplies: 2Last Post: 27th Aug 2011, 10:09 -
Compression: How much video quality loss?
By Djard in forum Video ConversionReplies: 9Last Post: 17th Jun 2011, 16:45 -
how to edit dvd video without loss in quality ?
By phpmysql348 in forum EditingReplies: 15Last Post: 2nd Oct 2008, 21:28 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03
