  1. Member Immortal25's Avatar
    May 2004
    Malaysia
    Dat is actually mpeg isn't it? For VCD? What software do I use that easily and accurately converts it to a proper DVD movie?
    Or if I don't want to burn it into a DVD movie, and just want a VCD, what do I do? ust drag them into Nero and burn like a regular vcd? But I have to choose that I want to burn a VCD right? Not ISO... ?
    Thanks in advance.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    VCDGear to extract the MPEG out of the dat file. Then you can author as DVD (you'll need to resample the audio to 48,000Hz) or author as-is to VCD. TMPGEnc DVd Author would be my option for the former and VCDEasy for the latter.
    If in doubt, Google it.
