i have converted an avi file to mpg for burning to dvd.
the subtitles are in the form of an srt file.
do i put the srt file somewhere in the VIDEO_TS folder?
or should i have somehow embedded the subtitles during the conversion process?
Hi-
Neither. You author with a program that excepts SRT subtitles or some other subtitle format to which you convert the SRT subs, so that they will be selectable. Embedding the subs into the video is amateurish and degrades the video quality. -
is TMPGEnc DVD Author such a program? if not which one do you recommend?Originally Posted by manono
Hi-
I don't use the TMPGEnc products, but I think I remember reading that it doesn't do subs. If true, that makes it pretty useless, in my opinion. If I need to create a menu, I use DVDAuthorGUI, which accepts SRT subs as input. If you don't need a menu, convert your subs to SUP format using SRT2SUP, and then author with Muxman or IFOEdit. DVDLab Pro (payware) can also do it, as can, I'm sure, many other authoring apps.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 06:15 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
