I attempted to install iTunes and Quicktime for an iPOD on my PC. Part way through the Quicktime install, which was automatic rather a choice and part of the entire procedure, it said it failed. When I clicked on the iTunes icon, it said it couldn't work without the current version of Quicktime (7.x rather than 6.x). I uninstalled eveything and attempted to re-install from the CD. Now it doesn't install Quicktime. Now when I click on the iTunes icon, it gives me an error message saying it can't run becasue it is missing files that are required, and to re-install. I have been through this twice with the same result. I'd appreciate any advice as to what to try and what is going on. Thanks.
What OS are you using? I don't think QT 7 will install on anything earlier than WinXP, maybe 2K.
If you are using XP, you can also try using System Restore to roll your system back to a point before the attempt at installing Quicktime and iTunes.
I've noticed WinAmp also allows you to access the iPod (a recent program addition) and transfer music to and from it, but I'm not sure if you have to have anything else installed (like QT and iTunes, for example). I've always just used iTunes.If cameras add ten pounds, why would people want to eat them?
ipod/itunes problem
By angryassdrummer in forum Portable VideoReplies: 9Last Post: 10th Mar 2011, 11:57 -
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
IPOD/Itunes video to DVD
By gregcpx in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2010, 02:49 -
iTunes won't synch video to iPod...why?
By Jabroni4872 in forum Portable VideoReplies: 2Last Post: 16th Oct 2008, 22:57 -
iTunes to iPod Very Slow
By Squid_uk in forum Off topicReplies: 3Last Post: 2nd Aug 2007, 05:55
