When I play an ntsc dvd my tv automatically goes to 4:3 and will not come off this setting nomatter what settings I change on my tv/dvd player and it does it with all ntsc so it is not just one disc... the tv and dvd player can play ntsc and I can watch the film fine but its stuck on 4:3 but when I play pal dvd's I can change the resolution at will.. why would this happen?
tv is an okishi - dont know the model number
dvd player is a Sony SLVD980
normal settings are just... normal. -
Try taking one of your problematic NTSC DVDs to a shop that sells your brand of TV, if not the same model, and your DVD player brand, if not the same model. Unless your TV and DVD are too old, try to find the same models.
At the shop, try playing your DVD in the same DVD player connected to a different TV and in a different DVD player connected to the same TV.
Borrow a friend's NTSC-compliant DVD player (if they have one) and see if it will play your NTSC DVDs on your TV. Take your DVD player to a friend's house and see if you can play your DVDs with your player on their TV.
Try different combinations to see if you can duplicate the behavior and narrow it down to being either a DVD player that has problems with NTSC or a TV that has problems with NTSC. Or maybe both. -
well it used to happen on my old dvd player aswell with alot of different ntsc discs so I know its the tv but is there anything I can do about it? besides obviously buying a new one
Read the manual and set it up correctly would be the best bet. That said, I can't find many references to that brand of TV, so maybe it just doesn't do what you want. Maybe you need to find a local repairer and take it into to him to have it setup correctly.
Read my blog here.
bd370 stuck
By mosfos in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Aug 2009, 21:05 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 21:39
