LF-MB121JD, the first Blu-Ray DVD burner is available
We have just discovered the LF-MB121JD in the Panasonic building, the first Blu-Ray burner that reads and writes BD-R and BD-RE and reads BR-ROM too. Blank discs are available in 25 and 50 (Dual Layer) formats.
The writing speed is set at 2x (72Mbps). Panasonic seems to have chosen sides in the format war, and according to Kazuhiro Tsuga, Panasonic supports Blu-Ray and they say that this is the only technology that will give consumers a true HD experience.
http://www.akihabaranews.com/en/news-11624-LF-MB121JD%2C%20the%20first%20Blu-Ray%20DVD...available.html
IO-DATA Blu-Ray burner
Panasonic announced their Blu-Ray burner today, and IO-DATA does the same... quite logical, because their burner is just a rebranded Pioneer drive! This BRD will be available in internal and external version. Before you go to the store to get one, pay a visit to your banker though, because the internal drive will cost 735 EUR and the external one will cost 810 EUR.
Results 1 to 19 of 19
Rare to see Panasonic, Pioneer and Sony on the same page.
http://www.kiva.org/about -
Let me guess a $1000 for the burner right????
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
yez - in retrospect , it is cheaper than the first dvd burners though (by far)
have they posted anything about encoding software for the burner
first dvd burner also didnt burn 72mb/s...hence the next question, wouldnt an external burner like SEVERLY limit burning speeds?
In theory external models would probably use Firewire800 or an external SATA connection.
I guess I should have kept up in this Blu Ray vs. HD DVD thing because Pioneer is in the blu ray camp? This is kinda shocking to me and between them and Sony I'm kinda finding myself leaning that way now.
Originally Posted by musher70
they are shipping them now ... and have stock"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by killerhex
Which CODECs are supported by Blu-ray Disc?
* For Video: MPEG-2, MPEG-4 AVC, and VC-1
* For Audio: LPCM, DTS, DTS-HD, Dolby Digital and Dolby Digital Plus"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
What's DTS-HD??
Originally Posted by yoda313
http://www.dtsonline.com/company/press/press-article.php?ID=267941252&yID=2004&cID=
http://www.dtsonline.com/consumer/dtshd.php
Highlights:
– DTS Digital Surround® (DTS' core 5.1 technology) has been selected as mandatory audio technology for both Blu-ray Disc (BD) and High Definition Digital Versatile Disc (HD-DVD).
– DTS-HD™ has been selected as an optional feature in both formats
– DTS-HD™ is a set of extensions to DTS' Coherent Acoustics audio coding system which encompasses DTS Digital Surround®, DTS-ES 6.1 discrete, DTS Neo:6 and DTS 96/24.
– DTS-HD™ is the only technology that will deliver lossless surround sound for these new disc formats, ensuring the highest quality audio performance available in the new standards.
– As a mandatory technology in the next generation standards, a DTS decoder will be built into every HD-DVD or Blu-ray Disc player.
– One single DTS-HD™ datastream on a disc can carry everything from standard DTS 5.1 playable on virtually all existing 280 million plus DTS decoders, all the way to lossless for next-generation systems."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
So is DTS-HD higher than the max DTS we get on dvds these days?? Whats the max? 1100 or something? I know on a ton of DTS tracks its like 754 or so.
At least they are saying this HD version is SUPPOSED to be backward compatible on traditional DTS receivers. Of course I won't believe it until I see itDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by BJ_M
you only need one of each audio and video -- several program do all the video above ... nothing does all the audio supported
it would be expensive"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Burning Blu-ray Data Disc with ImgBurn.
By bbanderic in forum DVD & Blu-ray WritersReplies: 25Last Post: 11th Oct 2015, 12:21 -
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 03:58 -
Sharing PC data in TV / Blu-ray doesn't work
By JN in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Feb 2011, 10:12 -
Custom Blu-ray meta data
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 1Last Post: 28th Jun 2009, 17:40 -
Blu Ray burner help
By dafoe in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Apr 2009, 00:14
