I have encountered a problem with making snapshots from DVD.
I used a PAL DVD, window is full screen, settings are snapshot to file, and I have tried all possible size settings (video source size, window size and enter size) but the result is always the same: left and right of the image is a black rim.
They can not be seen when the DVD is playing in PowerDVD.
I couldn't figure out why this happened, maybe it is a DVD problem (not in the meaning that they are damaged but a question of .. formats, layers etc.). Google and search in this forum didn't bring up anything.
Fuznny is that even with the print key which as I understand it makes a copy of everything visible on screen and only that, there are these black rims (which are not visible in playing or pause mode)
example:
Any ideas?
Use VirtualDub MPEG2 of VirtualDubMod for screen shots. PowerDVD, when it works, is blurry and dark.
Thanks.
I use virtualdub for single images, found the image quality usually worse than powerdvd but that probably depends on your settings.
I had a look at virtualdubmod but as I thought it is of no use for my project. The only way to capture is to clipboard and I need to make lots of snapshots. Copying to file is the best and actually only way to handle it.
I remember that BSPlayer is quite good usually and will check but I would still love an answer to my question (powerdvd) if there is one.
PowerDVD DX - Problem playing BluRay
By cdrake261 in forum Software PlayingReplies: 1Last Post: 24th Apr 2010, 15:46 -
powerdvd and bluray problem
By moler in forum Software PlayingReplies: 7Last Post: 7th Jul 2009, 14:54 -
PowerDVD: HD Scaling problem
By Kim Jespersen in forum Software PlayingReplies: 5Last Post: 10th Apr 2009, 05:44 -
AVCHD M2TS playback problem in PowerDVD
By prizi in forum Software PlayingReplies: 2Last Post: 4th Apr 2009, 07:18 -
PowerDVD 7 subtititles problem
By steppenwolf_27 in forum Software PlayingReplies: 3Last Post: 16th Sep 2007, 06:22
