hi
still struggling trying to burn a dvd. finaly toast compressed the disc, then when it was writing this came up;
THE DRIVE REPORTED AN ERROR
SENSE KEY=HARDWARE ERROR
SENSE CODE=OXO3 OXO1
anyone help? or know what this means, very frustrated
thanks
Larry
I tried running part of the error through Google, and got a variety of answers (even a link to a post on the Roxio support forums, though that didn't seem to want to load). Some suggested cleaning the drive, trying different media. The most 'extreme' suggestion was to try clearing the PRAM and see if that helps, though I'm not sure how, offhand, it would.
If cameras add ten pounds, why would people want to eat them? -
Sense Key =Hardware points to a problem with the Hardware,
ie. the dirve itself. In my own case, I've seen it apply to media
the drive was not rated to burn, and it would cause the
Laser to not calibrate correctly, thus giving a
SENSE KEY=HARDWARE ERROR .
Your computer specs aren't filled out, ( under your PROFILE)
so I can't really answer concretely. You should fix that
at your earliest convience. (hint, hint)
What I can tell you is this:
If you have a Pioneer DVR-106/A06 to a DVR-108/A08 drive,
the media you should be using is 8x rated or less.
If you are using a Pioneer DVR-109/A09 drive, then 16x media
should be fine, depending upon your FirmWare.
Please post back with the type of (brand and speed) DVD-R media
you are using, and the type of DVD Burner in your computer.
( Check Apple System Profiler)"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Burn movie from C Drive to DVD
By rwhite4photos in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2011, 17:36 -
Need Help! Can't get my DVD to burn from my hard drive!!!!
By kallimac in forum Newbie / General discussionsReplies: 3Last Post: 29th Jan 2010, 12:53 -
optical drive can read but will not burn
By marx321_04 in forum DVD & Blu-ray WritersReplies: 10Last Post: 6th Nov 2009, 06:50 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
How to burn a DVD from the hard drive
By webdude3 in forum DVD RippingReplies: 5Last Post: 21st Sep 2008, 19:00
