I just picked up a Phillips DVD player that can play DIVX DVD's. I have a few video files in DIVX .avi format that I just want to put on a DVD-R and play on the Phillips. Is this just a simple Data DVD burn with Nero? Just drop the files there? I heard you can't really get any menus in any authoring program on a DIVX DVD - yet. Thanks much for the help!![]()
Results 1 to 11 of 11
Yep just burn as normal data nothing special.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Cool thanks. I'm surprised no authoring software has created a menu system for DIVX discs yet.
That's because it's generally up to the player to provide a menu, if you're viewing DivX/XVid/MPEG/etc. straight from disc. If you want a better menu than what the player provides, you usually end up having to author a DVD-video disc.
If cameras add ten pounds, why would people want to eat them? -
Yeah, that seems to make sense. Thanks.
Look for a Divx Ultra certified player if you want pretty menus.
http://www.divx.com/certification/ -
I just made a data Divx disc with Nero and the Phillips 642 plays it. The menu that comes up is just very basic, kind of like a file menu in Windows. But it works.
i also have a 2 of the same divx compatible dvd players. i was so impressed with the first that i bought one for the bedroom, however recently if i burn say 8 films on a DVDR, only 4 or 5 of them will play. are there any other requirements of the file to ensure that the divx dvd will play them back? i assumed anything with the file type .avi would be ok to play?
sometimes the picture is very blocky and multicoloured and all you can hear is the sound too. kind of like a codec issue but surely you cant install codecs on your dvd player!?
any help would be greatly appreciated -
http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 22:32 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 12:28
