I tried using SubtitleCreator but I guess it's not totally idiot-proof.
I don't know how to use it. I have a .sub file and I need to convert it to .sup so that svcd2dvd can use it with my .avi file.
It asks for .IFO file -- which I don't understand. Why would I have .IFO file if I need svcd2dvd to convert .avi to all those files including the .IFO...
Any help or guide for the idiots?
Thanks.
Results 1 to 14 of 14
ok:
Start SubtitleCreator
Do File->Open text subtitles:
Then save:
It asks for frame rate after opening a text file and selecting a .sub file.
The avi is 25 fps, so I chose that and click 'Continue' and I get
'Error reading subtitle number 0'
Is this normal or something went wrong? -
Can you email me the sub file so i can take a look?
Sent you two emails. First one I forgot the attachment, hehe. Second one has it.
Thanks! -
I have a .srt file. How do I process those files. But keeping the original fonts.
Guido -
There is no font info in a .srt file:
lo chris, im having the same probs as original poster m8, do you have a how to guide of sorts for getting the sup file?
cheers. -
Is your sub file a text file or a binary one? (open in notepad)
Well you need to have text sub files to work with subtitlecreator. Try the following to get what you need.... http://www.google.com/search?num=100&hl=en&lr=&safe=off&rls=GGLJ%2CGGLJ%3A2006-07%2CGG...se&btnG=Search
is there a program that can create text files from the binary subs file? only reason i ask is that the subs are not available for most films yet the binary ones are.
Try Subtitle Workshop or others in the subtitles cat in the Tools section.
