Can someone tell me where I can find out if my camcorder will accept a particular type of 8cm DVD?
(When I say type... I mean brand name.)
Thanks.
OM
8 cm DVDR follow the same specification as standard DVDR. Use the any +R/W, if you want to re-use the disc, else stay with what the manual say. They are all costly enough, the user only buy them at most as a 5 pack, mostly single. Basically, if the DVDcamcorder is good, it should able to take any brand.
OM2, you should know that the brand name does not always indicate the manufacturer. The media code determines who really made the disc. Look to the left for 'DVD Media' and it lists the real manufacturer for the different media codes and brands.
Help me find the right file type
By Solidify in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2011, 08:00 -
How to find a subtitle's characteristics from a DVD (font type, size etc.)?
By thinredline in forum SubtitleReplies: 6Last Post: 5th Feb 2011, 15:20 -
How do I find out which disks my PC will accept?
By aelfheah in forum DVD RippingReplies: 8Last Post: 13th Jan 2011, 08:09 -
Mini DVD-R Samsung camcorder file type problem
By SASA39 in forum Video ConversionReplies: 4Last Post: 17th Jan 2009, 10:53 -
Help burning multiple 8cm DVD+RW from Camcorder to 12cmDVD+RW
By WOWSY in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2007, 13:48
