Hi,
I have two .avi files, in total it is about 80 minutes. However, 1 dvd only fit about 62 minutes.
I bought a Pinnacle Instant CD?DVD 8 in which it has a Pinnacle Expression. This tool can fit more than 80 minutes happily. However, when I write it to dvd, after about 10 minutes, it has runtime error. Does anyone have the same experience?
Is there any other way to fit 80 minutes into one dvd? If yes, how and please tell the steps and program. For a 60 minutes video, I use Sonic MyDVD, but it only accepts up to about 60 minutes.
You can fit several hours per dvd if you lower the video bitrate/video quality. Just use better tools like Convertxtodvd or convert/encode with a separate tool where you can set the exact output size like tmpgenc and author with tda.
16:9 .avi file doesnt fit the analog TV
By rekotc in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2012, 14:01 -
Please Help!-2:46:22 (690 MB) .WMV file will NOT fit on DVD which is 4.7G
By facepalm!! in forum Newbie / General discussionsReplies: 17Last Post: 6th Jan 2012, 04:52 -
avi files can only play up to 40 minutes in DVD player, why?
By ericdunn in forum Newbie / General discussionsReplies: 8Last Post: 7th Apr 2010, 09:37 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 12:41 -
Unable to fit file to dvd?
By Ado in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 20:20
