I'm capturing video from a Sony Hi8 camcorder using a Canopus ADVC-100 analog/digital converter into Firewire. The capture video has some flutter/corruption at the bottom of the frame (go here for a short sample video: http://www.sethjones.net/video/test.mpg). I've tried using multiple cameras and multiple capture software (Pinnacle Studio 9, VirtualDub) with no change.
I think the problem is in the Canopus device. My thought is to strip off the bottom part of the frame in editing. My question is can I so this in editing software and if so, what editing software would you recommend? Thanks for any help you might provide.
Seth
I doubt the problem is with the ADVC-100. I've used the unit for more than 2 years, and I have never had that problem, using all sorts of inputs.
That said, one of the better DV editors is VirtualDub. I use VirtualDub Mod normally. You can easily crop the bottom part of the video. In your sample, though, that would not be shown on a normal TV as it appears to be in the 'overscan' area. But you can crop it if your end video is being made to show on a computer only. -
Was not aware of an overscan area. I just did a test burn to a DVD and played it on TV and you're right, the flutter area at the bottom is not visible. Thanks for the guidance.
Good deal. Not everyone is aware of 'overscan'. Sometimes, depending on the TV, around 5% or a little more of the edges are lost. This usually comes up with VCR captures, as VCR video has a fair amount of edge noise, some it from the VCR 'head switching noise'.
A computer shows the whole frame. It's always a good idea to check it on a TV before making any final decisions about your video. Video also generally shows darker on a computer screen than a TV screen and interlace doesn't display properly on a computer monitor unless you use a program that handles interlace video properly. Just a few things to remember when transferring a computer video to a TV format.
Problem with TS, possible corruption?
By Killer3737 in forum DVB / IPTVReplies: 22Last Post: 9th Jan 2011, 11:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
MP4 corruption Need Help
By yus in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 14:37 -
Still Frame and Field Capture?
By swingmaster in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2009, 10:28 -
Disc corruption problem
By coody in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 00:06
