What are the two included light things for that go wiht the inputs in the back fo the receiver for? I must be dumb...
IR Emitters. they are for blasting IR signals to components which are not within line-of-sight range of the remote's reciever.
no, you're not dumb.. lol. You'd only need to use them if you have a set top box and need to change the channels on there. If your cable feed can be tuned, then there should be no need to use it.
Hope this clears it up more!
Canopus ADVC55 red light status indicator
By bobmccredie in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2008, 00:10 -
Using a printed list of movies and the number pad on the remote
By bwd777 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Sep 2008, 18:15 -
LG LRH-780 remote control model number needed
By gm3317 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 27th Aug 2008, 21:20 -
Microsoft WST Codec filter & Hauppauge Remote?
By amdk62 in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2007, 11:21 -
Encore DVD and remote control number buttons
By geohei in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2007, 09:23
