I have burned somewhere about 200 dvd and not a single coaster. Now i've got 3 in row with different software, nero or roxio. When I do an erase dvd-rw it erased for about 10 sec then ejacts process usually takes 2:00. Tried to burn to dvd-rw to avoid coasters, but programs freezes about 10% in. Does this seem like a burner failure, even so it is still recognized. Thanx all.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
First thing I would suspect is dirt on the laser lens. Try cleaning it. If that gets you nowhere, then try different DVD media. Media is the usual cause of burning problems. Also try a ISO burn. That should rule out your burning software as the problem. Last, try flashing your burner to the latest firmware. If none of this works, maybe the DVD burner is failing.
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 17:34 -
AVI to DVD w/ FAVC, Failure to Read
By Bullneck in forum Video ConversionReplies: 3Last Post: 2nd Apr 2008, 19:09 -
question about repeated DVD burn failure at about 90%
By jimdagys in forum Newbie / General discussionsReplies: 18Last Post: 18th Mar 2008, 22:34 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28 -
RECOVER DVD - Power Failure Sony GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th May 2007, 12:13
